Whisperings:Solo Piano Radio
  POV-Ray : Documentation : 2.4.1.14 Torus
  POV-Ray 3.6 Documentation Online View
2.4.1.13 Text   2.4.2 Finite Patch Primitives
2.4.1.14 Torus
A torus is a 4th order quartic polynomial shape that looks like a donut or inner tube. Because this shape is so useful and quartics are difficult to define, POV-Ray lets you take a short-cut and define a torus by:
TORUS:
    torus
        Major, Minor
        [TORUS_MODIFIER...]
TORUS_MODIFIER:
    sturm | OBJECT_MODIFIER
Torus default values:
sturm : off
where Major is a float value giving the major radius and Minor is a float specifying the minor radius. The major radius extends from the center of the hole to the mid-line of the rim while the minor radius is the radius of the cross-section of the rim. The torus is centered at the origin and lies in the x-z-plane with the y-axis sticking through the hole.
Major and minor radius of a torus.
The torus is internally bounded by two cylinders and two rings forming a thick cylinder. With this bounding cylinder the performance of the torus intersection test is vastly increased. The test for a valid torus intersection, i.e. solving a 4th order polynomial, is only performed if the bounding cylinder is hit. Thus a lot of slow root solving calculations are avoided.
Calculations for all higher order polynomials must be very accurate. If the torus renders improperly you may add the keyword sturm to use POV-Ray's slower-yet-more-accurate Sturmian root solver.
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
