When developing POV-Ray scenes it is often useful to do low quality test runs that render faster. The +Q
command line switch or Quality INI option can be used to turn off some time consuming color pattern and
lighting calculations to speed things up. See "Quality Settings"
for details. However all settings of +Q5 or Quality=5 or lower turns off pigment
calculations and creates gray objects.
By adding a quick_color to a pigment you tell POV-Ray what solid color to use for quick renders
instead of a patterned pigment. For example:
gradient x
color_map{
[0.0 color Yellow]
[0.3 color Cyan]
[0.6 color Magenta]
[1.0 color Cyan]
turbulence 0.5
lambda 1.5
omega 0.75
octaves 8
quick_color Neon_Pink
This tells POV-Ray to use solid Neon_Pink for test runs at quality +Q5 or lower but to
use the turbulent gradient pattern for rendering at +Q6 and higher. Solid color pigments such as
pigment {color Magenta}
automatically set the quick_color to that value. You may override this if you want. Suppose you have
10 spheres on the screen and all are yellow. If you want to identify them individually you could give each a different quick_color
like this:
sphere {
<1,2,3>,4
pigment { color Yellow quick_color Red }
sphere {
<-1,-2,-3>,4
pigment { color Yellow quick_color Blue }
and so on. At +Q6 or higher they will all be yellow but at +Q5 or lower each would be
different colors so you could identify them.
The alternate spelling quick_colour is also supported.
